[Mapserver-dev] configure script problems with multiple GD
Steve Lime
steve.lime at dnr.state.mn.us
Tue Oct 26 00:29:12 EDT 2004
Sean: On my mac box GD_LIBDIR does seem to be being set correctly. That
is, if I install gd someplace non-standard:
./configure --with-gd=/usr/local/test
gives me:
GD_INC= -I/usr/local/test/include
GD_LIB= -L/usr/local/test/lib -lgd -ljpeg -lfreetype -lpng -lz
in the Makefile. Linking still uses whatever version of GD is found
first though. I think configure is ok. Perhaps there is a linker option
to ignore the second version, but I've never run across it. Not having
multiple versions of the same library installed doesn't seem too big a
minimum requirement to me. I know it's not idiot proof though and it
would be nice to fix.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Sean Gillies <sgillies at frii.com> 10/25/04 12:45 PM >>>
Users continue to report problems with the configure script
not picking up their own local installations of GD. After
looking in configure.in, I'm not sure that GD_LIBDIR is
being properly set before we use AC_CHECK_LIB to look for
gdImageSetAntialias (test for GD version > 2.0.12), or that
adding -L$GD_LIBDIR will work to push the user-configured
GD location ahead of other system GD installations.
I'm also not experienced enough with autoconf to fix this
myself. Could we set the right person to this task before
a final 4.4.0 release?
Not every user will have the option of removing every
conflicting GD from their system, or of modifying their
linker's system search order.
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
Mapserver-dev mailing list
Mapserver-dev at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
