[Mapserver-dev] MS_ERRORFILE
Daniel Morissette dmorissette at dmsolutions.ca
Thu Oct 28 10:49:09 EDT 2004
Frank Warmerdam wrote:
> However, I am wondering if we can go a bit further, and have turning on map
> level debugging always set MS_ERRORFILE=stderr *if* MS_ERRORFILE isn't
> already
> set.  This would mean, in my mind, that turning on the MAP DEBUG
> statement would
> help get alot more sigificant debug info into the log.
> Any objections?  Questions?  Suggestions?
Frank,
I like the idea, and would also suggest adding a -all_debug option to
the mapserv CGI since this is what I use for debugging most of the time
instead of shp2img.
Actually, I had already opened bug 709 to try to solve this issue so I
think we should move the discussion there:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=709
The title of the bug was to enable the LOG directive in MapScript, but
my goal was really to expose the errors and debugging information more
easily to the users, so your suggestion would be an appropriate fix.
I'll copy this comment to the bug.
Daniel
  DM Solutions Group              http://www.dmsolutions.ca/
