[Fwd: Re: [Mapserver-dev] configure script problems with multiple
GD]
Daniel Morissette
dmorissette at dmsolutions.ca
Thu Oct 28 12:59:40 EDT 2004
Dirk Tilger wrote:
> It depends. For example, if I do:
> | dirk at o2:~/src/mapserver-4.2.5-dirk/mapscript/php3
> ldd php_mapscript.so
> | libtiff.so => /usr/freeware/lib32/libtiff.so
> | libfreetype.so.7 =>
> /usr/freeware/lib32/libfreetype.so.7
> | libpng.so => /usr/freeware/lib32/libpng.so
> | libz.so => /usr/freeware/lib32/libz.so
> | libXpm.so => /usr/freeware/lib32/libXpm.so
> | libX11.so.1 => /usr/lib32/libX11.so.1
> | libproj.so.1 => /usr/freeware/lib32/libproj.so.1
> | libpdf.so.2 => /usr/freeware/lib32/libpdf.so.2
> | libgd.so.3 => /usr/people/dirk/lib/libgd.so.3
> | libm.so => /usr/lib32/libm.so
> | libjpeg.so => /usr/freeware/lib32/libjpeg.so
> | libc.so.1 => /usr/lib32/libc.so.1
> I see no version numbers for libjpeg. If it would
> instead link against 'libgd.so', there would be no way
> to tell which library the right one is.
Yuck!
>>The real long term solution to this IMHO is to
>>provide precompiled
>>binaries so that the users don't have to compile
>>themselves.
> Good idea. I'd like to contribute IRIX+Solaris bins.
> But this will not solve the problem as long as we not
> supply/static-link all the needed libraries as well.
FYI, we've packaged Solaris and AIX binaries before, and the best way
we've found to make this work has been to install the whole thing under
a /opt/mapserver tree and include all shared libs that we need in
/opt/mapserver/lib and use the LD_LIBRARY_PATH (Solaris) or LIBPATH
(AIX) to point to our lib directory. This way our libs are used in
precedence over the system libs for MapServer. This results in a very
stable install, the only drawback is the size of the package and the
fact that we end up duplicating some system libs in our lib directory.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
