[Mapserver-dev] include directive for mapfiles
Paul Ramsey
pramsey at refractions.net
Fri Oct 29 11:54:37 EDT 2004
One thing to note/remember when moving to CPP processing of your map
files (particularly if you are retrofitting an existing file set) is
that you have to convert all your # comments to c-style comments, either
// or /* */ blocks. Took me a little while to figure out that my errors
weren't caused by my code, but by my comments. :)
Kralidis,Tom [Burlington] wrote:
> Thanks to all for this.
> Here's a small example:
> header.txt:
> <html>
> <head>
> <title>HEADER</title>
> </head>
> <body>
> body.txt
> <h1>hi</h1>
> footer.txt
> </body>
> </html>
> mapfilepp.c:
> #include "header.txt"
> #include "body.txt"
> #include "footer.txt"
> To run:
> $ gcc -ansi -pedantic -E -P mapfilepp.c
>>-----Original Message-----
>>From: Daniel Morissette [mailto:dmorissette at dmsolutions.ca]
>>Sent: Friday, 29 October, 2004 10:11
>>To: Kralidis,Tom [Burlington]
>>Cc: mapserver-dev at lists.gis.umn.edu
>>Subject: Re: [Mapserver-dev] include directive for mapfiles
>>>Paul,
>>>No I haven't. What is the approach? And this sounds like
>>making mods
>>>to the source code? If yes, I was looking for a canned, runtime
>>>solution.
>>This is an FAQ. Google for "mapfile include preprocessor site:umn.edu"
>>Daniel
>> Daniel Morissette dmorissette at dmsolutions.ca
>> DM Solutions Group http://www.dmsolutions.ca/
> Mapserver-dev mailing list
> Mapserver-dev at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
