[Mapserver-dev] Modularizing mapserver
Sean Gillies sgillies at frii.com
Thu Sep 16 12:48:18 EDT 2004
On Sep 16, 2004, at 9:40 AM, Attila Csipa wrote:
> On Thursday 16 September 2004 17:16, Sean Gillies wrote:
>> Speaking of conditional compilation: some files like mapimagemap.c
>> and mapmygis.c that are clearly (IMO) non-core code are compiled
>> whether the user wants them or not.  Would the developers of these
>> files be willing to work with me to start on a source reorganization?
> I have no problem with that. A few notes: mapmygis is an adaptation of
> mappostgis so it should behave the same way (unless this has been
> changed in
> the meantime or I made an error in the config/make process), and only
> the
> placeholder functions are compiled in if the --with-mygis option is not
> specified (or at least that's how it is intended to be, if it isn't,
> it's a
> bug). Mapimagemap generation could/should be optional as well.
My mistake -- I overlooked the #ifdef USE_MYGIS.
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
