[Mapserver-dev] STATUS for LABELS
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Sep 17 21:44:43 EDT 2004
Franck,
This is an interesting idea. Can you provide more information on how you
want this feature to work. For example, is this a global switch that
just disables all labels. This would be somewhat problematic since that
would turn off things like copyright labels and such.
Do you envision this as an attribute that is specified in the LABEL ...
END block. How do you plan to use this feature?
-Steve W.
Franck Martin wrote:
> A LAYER has STATUS ON/OFF but a LABEL does not have the same capability.
> I make therefore a Request for Feature Enhancement (RFE)
> Cheers
