[Mapserver-dev] buffer
sudip dey sudip_mca at sify.com
Wed Sep 22 01:13:23 EDT 2004
This message is in MIME format.
---MOQ1095831803d165e51a796afa29ffc1c9f018ceb1ef
Content-Type: text/plain
Content-Transfer-Encoding: 8bit
Hello,
        i am working upon a GIS-project using PHP-mapscript and mapserver.Now i have to buffer areas of the map which are at a given distance away from a line layer.I have to shade the region with different color.
        Any comments and code in this respect will be greatfully accepted.
        Thanking you............Sudip
Content-Type: text/html
<pre>Hello,
        i am working upon a GIS-project using PHP-mapscript and<br>mapserver.Now i have to buffer areas of the map which are at a given<br>distance away from a line layer.I have to shade the region with<br>different color.
        Any comments and code in this respect will<br>be greatfully accepted.
        Thanking you............Sudip </pre>
---MOQ1095831803d165e51a796afa29ffc1c9f018ceb1ef--
