[Mapserver-dev] cvs compile error
Sean Gillies
sgillies at frii.com
Sat Sep 25 19:13:40 EDT 2004
On Sep 25, 2004, at 4:50 PM, Kralidis,Tom [Burlington] wrote:
> (For some reason, I get email errors when trying to email:
> mapserver-users at lists.umn.edu
> mapserver-users at lists.gis.umn.edu
> ..hence my email to the dev list)
> Hi,
> I'm trying to compile the cvs dist on a Fedora Core 2 box, but running
> into errors in mapwfs.c. Below is the error message:
> ./configure --with-freetype=/usr/local/bin/freetype-config
> --with-zlib=/usr/local --with-png=/usr/local --with-jpeg=/usr/local
> --with-xpm=/usr/local --with- libiconv=/usr/local --with-gd=/usr/local
> --with-pdf=/usr/local --with-eppl --with-proj=/usr/local
> --with-geos=/usr/local/bin/geos-config --with-gdal=/usr/lo
> cal/bin/gdal-config --with-ogr=/usr/local/bin/gdal-config
> --with-postgis=/usr/local/pgsql/bin/pg_config --with-wfs --with-wcs
> --with-wmsclient --with-wfscli ent --without-tiff
> --with-curl-config=/usr/local/bin/curl-config
> gcc -c -O2 -fPIC -Wall -DIGNORE_MISSING_DATA -DNEED_STRLCAT
> -DUSE_EPPL
> -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS_SVR -DUSE_WMS_LYR -DUSE_WFS_SVR
> -DUSE_WFS_LYR
> -DUSE_WCS_SVR -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG
> -DUSE_GD_WBMP
> -DUSE_GD_FT -DGD_HAS_GDIMAGEGIFPTR -DUSE_PDF -DUSE_OGR -DUSE_GDAL
> -DUSE_GEOS -DUSE
> _ICONV -DUSE_POSTGIS -I/usr/local/include -I/usr/local/include
> -I/usr/local/pgsql/include -I/usr/local/i
> nclude -I -I/usr/local/include mapwfs.c -o mapwfs.o
> mapwfs.c: In function `msWFSPrintRequestCap':
> mapwfs.c:229: error: `encoded' undeclared (first use in this function)
> mapwfs.c:229: error: (Each undeclared identifier is reported only once
> mapwfs.c:229: error: for each function it appears in.)
> mapwfs.c: In function `msWFSDescribeFeatureType':
> mapwfs.c:627: error: `stream' undeclared (first use in this function)
> mapwfs.c: In function `msWFSGetFeature':
> mapwfs.c:1148: error: `stream' undeclared (first use in this function)
> mapwfs.c: At top level:
> mapwfs.c:305: warning: `msWFSGetGeomType' defined but not used
> make: *** [mapwfs.o] Error 1
> Any idea what's going on here? I've noticed that mapwfs.c and mapwms.c
> have had CVS changes to encoding.
> Cheers
> ..Tom
Makes me glad that I didn't do a cvs update today.
Don't commit code that doesn't compile, please!
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
