[Mapserver-dev] cvs compile error
Daniel Morissette dmorissette at dmsolutions.ca
Sun Sep 26 09:00:08 EDT 2004
Kralidis,Tom [Burlington] wrote:
> I still get error, when changing in Makefile as per below:
> ICONV=
> ..as well as commenting out the declaration altogether.
> ./libmap.a(mapgd.o)(.text+0x9edd): In function `msGetEncodedString':
> : undefined reference to `libiconv_open'
Tom,
Did you do a 'make clean' after editing the Makefile? The iconv code in
msGetEncodedString() is inside #ifdef USE_ICONV, so if you really
removed the -DUSE_ICONV then it should not be compiled in.
I'll see if I can reproduce the orginal issue at this end, we probably
need to tune the configure detection of libiconv to handle something
specific to your system configuration. If I can't reproduce the problem
then I may need you to create a bug and attach your configure options
and configure output.
Daniel
  DM Solutions Group              http://www.dmsolutions.ca/
