[Mapserver-dev] Internationalization of MapServer
Howard Butler
hobu at iastate.edu
Mon Sep 27 11:26:57 EDT 2004
Folks,
I saw that Julien checked in code that closes out bug 858 and implements
encoding support in CVS MapServer. This is a great feature, but I have a
couple of questions regarding encodings, builds, and their impact.
1. The encoding support requires the GNU iconv library. I see that there
is a conditional #ifdef USE_ICONV in mapgd.c to enable encodings. Will
iconv be optional to use with MapServer?
2. If iconv is *not* optional, this makes life really interesting. iconv
support in gd means that both GD and FreeType need to be compiled with
it. In windows land, most folks use the pre-compiled binaries for both GD
and FreeType that don't normally come with this compiled in.
While iconv support is fairly trivial in unix-like installations, getting
it and the other two required libraries (GD and freetype) compiled together
and working correctly could be a monumental task for someone attempting to
compile a windows build.
Howard
