[Mapserver-dev] cvs compile error
Julien-Samuel Lacroix
jlacroix at dmsolutions.ca
Mon Sep 27 16:09:35 EDT 2004
Tom,
I opened a bug about this issue and added you in CC to give more
explanations.
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=910
If you can maybe put the end of the capabilities document it would be nice.
I also opened
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=909
About your libiconv build problem. Again if you can give us more
information it would be nice. Do you have iconv.h on your system? Does
your GD detected it? Does mapserver detected it?
Thanks
Julien
Kralidis,Tom [Burlington] wrote:
> I'm not sure what happened, but when I rebuild as per below, everything
> compiles fine. When I issue a WMS 1.1.1 GetCapabilities, I get a
> partial XML document response.
> OS:
> $ uname -a
> Linux devgeo.cciw.ca 2.6.5-1.358smp #1 SMP Sat May 8 09:25:36 EDT 2004
> i686 i686 i386 GNU/Linux
> ...so I'm not sure what's going on here. Can someone verify this is not
> only me?
> ..Tom
> Mapserver-dev mailing list
> Mapserver-dev at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
Julien-Samuel Lacroix jlacroix at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
