[Mapserver-dev] mode of map
sudip dey
sudip_mca at sify.com
Wed Sep 29 02:37:05 EDT 2004
This message is in MIME format.
---MOQ1096438025643771028e04da5291954a58afc9491a
Content-Type: text/plain
Content-Transfer-Encoding: 8bit
Hello,
i am working upon a project using php-mapscript & mapserver in windows environment.
I need to provide the facility so that user can view the map in two different modes -- one is browse mode in which one can pan the map and the other one is map-mode where the user can\'t pan the map.Though till now i am working upon only the browse-mode which is working properly but it\'s becoming difficult for me to find out the solution for map-mode .
Any code or suggesation in this respect will be greatfully accepted.
Thanking you ................Sudip
Content-Type: text/html
<pre>Hello,
i am working upon a project using php-mapscript &<br>mapserver in windows environment.
I need to provide the<br>facility so that user can view the map in two different modes -- one is<br>browse mode in which one can pan the map and the other one is map-mode<br>where the user can\'t pan the map.Though till now i am working upon only<br>the browse-mode which is working properly but it\'s becoming difficult<br>for me to find out the solution for map-mode .
Any code or<br>suggesation in this respect will be greatfully accepted.
<br>Thanking you ................Sudip </pre>
---MOQ1096438025643771028e04da5291954a58afc9491a--
