[Mapserver-dev] Exceptions for Java, Ruby, C# mapscript in 4.4
Sean Gillies
sgillies at frii.com
Thu Sep 30 18:10:12 EDT 2004
Yes? Basically all it does is croak(). I don't use the Perl mapscript
at all, so I don't know what the impact will be on existing scripts.
Sean
On Sep 30, 2004, at 4:03 PM, Steve Lime wrote:
> If they are not too hard to add would it make sense to be as consistent
> as
> possible between languages. I want Perl exceptions by the way...
> Steve
>>>> Sean Gillies <sgillies at frii.com> 9/30/2004 4:32:04 PM >>>
> Hi all,
> Thanks to work by Umberto Nicoletti there will be exceptions in
> Java mapscript using SWIG's exception library
> http://www.swig.org/Doc1.3/Customization.html#Customization_nn7
> Do Ruby and C# developers and users want exceptions? I won't add
> them unless someone speaks up on behalf of their favorite
> map-scripting
> language.
> cheers,
> Sean
> Sean Gillies
> sgillies at frii dot com
> http://users.frii.com/sgillies
> Mapserver-dev mailing list
> Mapserver-dev at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
