mapserver-4.0.1 version source code documentation
Daniel Morissette dmorissette at DMSOLUTIONS.CA
Tue Apr 12 10:53:49 EDT 2005
Akio Neuchi wrote:
> I recently joined to the MapServer community.
> Trying to make a Japanese version, I am facing some problems.
> I wonder if I can get complete documentations (file descriptions) of .c
> and .h source code.
>  ( mapserver-4.0.1.tar version)
> Thank you for your attention.
There is no formal description of the source files available anywhere.
However you could use a tool such as Doxygen (http://www.doxygen.org/)
to generate some documentation based on the source files. That could
give you at least an idea of what's in each file.
BTW, MapServer 4.0.1 is quite old, you should work with the current
release. i18n support has been added to MapServer 4.4, so I would
recommend that you use that version instead, and you would not need to
do any work to produce maps with Japanese fonts, assuming that's what
you were planning to do. Look for the ENCODING keyword in the mapfile
reference at http://mapserver.gis.umn.edu/doc44/mapfile-reference.html
Daniel
  Daniel Morissette               dmorissette at dmsolutions.ca
  DM Solutions Group              http://www.dmsolutions.ca/
