mapserver-4.0.1 version source code documentation
Akio Neuchi neuchi at TCI-COM.BIZ
Mon Apr 18 20:59:42 EDT 2005
Hello,
I got a trouble with the CGI interface.
The following message came from MapServer when a client was sending bunch of
node parametres by POST on the script.
...trying to POST /cgi-bin/mapserv, cgi_scan_headers
 reports: HTTP4044: the CGI program
/var/opt/SUNWappserver7/domains/domain1/server1/cgi-bin/mapserv
did not produce a valid header (program terminated without a valid CGI
header.
Check for core dump or other abnormal termination)
Is this because of cgiutil.c's getenv("CONTENT_LENGTH") setting?
If so what is the best way or common to expand the "CONTENT_LENGTH" by
MapServer user?
If not how can I solve this problem?
I appreciate your help.
Akio
-----Original Message-----
From: Daniel Morissette [mailto:dmorissette at dmsolutions.ca]
Sent: Thursday, April 14, 2005 12:54 AM
To: neuchi at tci-com.biz
Cc: MAPSERVER-DEV at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-DEV] mapserver-4.0.1 version source code
documentation
Akio Neuchi wrote:
> As a matter of fact, do you know if the 4.4 version runs stably on Solaris
> 9/04?
I haven't built or used MapServer 4.4 on Solaris yet, but previous
releases of MapServer used to work fine on Solaris, so I wouldn't expect
too many problems with this release.
  Daniel Morissette               dmorissette at dmsolutions.ca
  DM Solutions Group              http://www.dmsolutions.ca/
