mapserver-4.0.1 version source code documentation
Akio Neuchi
neuchi at TCI-COM.BIZ
Thu Apr 21 07:34:08 EDT 2005
Thanks Daniel!
I will try installing v4.2.5 and see how it goes.
Akio
-----Original Message-----
From: Daniel Morissette [mailto:dmorissette at dmsolutions.ca]
Sent: Wednesday, April 20, 2005 10:29 PM
To: Akio Neuchi
Cc: MAPSERVER-DEV at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-DEV] mapserver-4.0.1 version source code
documentation
Akio Neuchi wrote:
> Unfortunately at this stage I have to work with the old version 4.0.1,
> because this is the only active one.
The problem working with older versions is that you may just be running
in old issues/bugs that are fixed in the current release. In this
specific case, your problem may be related to the following that was
fixed in v4.2:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=567
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
