fast-cgi
Fernando Simon
fsimon at UNIVALI.BR
Wed Apr 27 08:48:49 EDT 2005
Hi Hubb,
I saw this problem with an old version of maporaclespatial.c. But in
my tests I saw that the same problem with memory occour without Oracle
Spatial connection, near +0.5% (I have 512Mb in my system) for every
fastcgi request.
I updated a big fix to the maporaclespatial.c in the last month, I
don't know what version Bart used. But I believe that the last version
can solve the memory problem. I will check the last version with
fastcgis support.
About the error message, it's occour when the system can't allocate
more memory to mapserver (maporaclespatial.c).
Bart, what version of maporaclespatial.c was used?
Thanks.
Fernando Simon
Mapserver and Oracle Spatial developer
G10 - Laboratorio de Computacao Aplicada - Brazil
http://g10.cttmar.univali.br - UNIVALI/CTTMAR
Huub wrote:
> Hi list (Bart),
> i'm looking at a few thing concerning fastcgi and oracle spatial.
> We're using OracleSpatial10g and fastcgi in a 4.5 compile, actually it
> was compiled by Bart van den Eijnden :-) from recent sources
> We found that every maprefresh uses more and more memory, it's never
> released.
> Maybe that this has got something to do with the included error
> fastcgi is supposed to keep open connections, but i think it does
> something more.
> just now i stopped apache and memoryusage dropped from 2.5Gb to 300Mb ....
> <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
> <!DOCTYPE ServiceExceptionReport SYSTEM
> "http://schemas.opengeospatial.net/wms/1.1.1/exception_1_1_1.dtd">
> <ServiceExceptionReport version="1.1.1">
> <ServiceException>
> msDrawMap(): Image handling error. Failed to draw layer named
> 'hn_auto'.
> msOracleSpatialLayerWhichShapes(): OracleSpatial error. *Cannot
> allocate items buffer*
> </ServiceException>
> </ServiceExceptionReport>
> i found this in the archives
> (http://mapserver.gis.umn.edu/wilma/mapserver-dev/0409/msg00149.html)
> where the error is 'thrown'
> > /* allocate enough space for items */
> > if (layer->numitems > 0) {
> > layerinfo->items = (item_text_array *)malloc(
> > sizeof(item_text_array) * layer->numitems );
> > if (layerinfo->items == NULL) {
> > msSetError( MS_ORACLESPATIALERR,
> > "Cannot allocate items buffer",
> > "msOracleSpatialLayerWhichShapes()" );
> > return MS_FAILURE;
