DWithin using a polygon on MapInfo tab file(OGR)
Yewondwossen Assefa assefa at DMSOLUTIONS.CA
Wed Apr 27 13:03:19 EDT 2005
Bart,
  I have updated bug 1335 and commited the fix. Is it possible to test
with latest CVS version. I don't think there is going to be a 4.4.3
version since the 4.6 is about to come so I did not port the fix in that
branch.
Later,
Bart van den Eijnden wrote:
> Hi Assefa,
> I am now even getting crashes using shapefiles as a datasource.
> Will add that to the bugreport/testcase.
> Thanks for looking into this.
> Best regards,
> Bart
> Syncera-ITSolutions
> Postbus 270
> 2600 AG  DELFT
> tel.nr.: 015-7512436
> email: BEN at Syncera-ITSolutions.nl
>>>>Yewondwossen Assefa <assefa at dmsolutions.ca> 04/27/05 06:01pm >>>
> Looking into this ...
>>Hi list,
>>I was trying to perform a DWithin request (Mapserver WFS) on a Mapinfo layer (OGR), but Mapserver crashes.
>>I then tried converting the Mapinfo file to shapefile and everything worked fine, so this is probably a bug somewhere.
>>I have opened up the following bug report with a testcase/attachment:
>>http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1335
>>Maybe somebody knows whether or not this has been fixed in CVS?
>>Best regards,
>>Bart
>>Syncera-ITSolutions
>>Postbus 270
>>2600 AG  DELFT
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
