Layer Virtualization and SDE
Howard Butler
hobu at IASTATE.EDU
Thu Dec 8 13:05:58 EST 2005
Folks,
Attempting to compile up mapsde.c with USE_SDE defined in a post-RFC
3 world has created an issue. SDE has a function in it to return the
index column for the table that someone has requested. This function
is called msSDELayerGetRowIDColumn. This function prototype used to
exist in map.h with all of the rest of the SDE functions.
After the virtualization, this prototype was removed from
map.h. This causes things not to compile, but the larger issue is
that should there be a place holder for this type of thing in the
layer virtualization? Would other data providers potentially have a
need to return which column is the index?
Please give me some advice on what to do. Short-term, I can just
stick the prototype in map.h and be on my way, but I'd rather things
behave uniformly.
Howard
