Fuzzy brushes...
Ed McNierney
ed at TOPOZONE.COM
Wed Dec 14 07:32:18 EST 2005
Steve -
I had been meaning to offer to do some testing; thanks for the post.
I'll download and take a look today.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
Phone: +1 (978) 251-4242
Fax: +1 (978) 251-1396
ed at topozone.com
-----Original Message-----
From: UMN MapServer Developers List [mailto:MAPSERVER-DEV at LISTS.UMN.EDU]
On Behalf Of Steve Lime
Sent: Wednesday, December 14, 2005 1:05 AM
To: MAPSERVER-DEV at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-DEV] Fuzzy brushes...
In case anyone would like to test I have hooked up the fuzzy brush
generator in mapgd.c for the most trivial line drawing case (no symbol
defined). To use:
1) define a 24-bit output format, IMAGETYPE 'png24' works nicely
2) define a simple style definition for a line layer (or polygon
outline) like so:
STYLE
WIDTH 3
COLOR 255 0 0
ANTIALIAS TRUE
END
3) set TRANSPARENCY ALPHA to enable alpha blending
Caveats:
- brushes need to be odd sized. That requirement is enforced in the
brush builder which detects even sized requests and rounds up. Symbol
scaling should work just fine.
- you'll notice that the line "fades" in at the start which is due to
the transparent nature of the brush. Adjusting the default "hardness"
may minimize that.
That should do it. I will enable for circles layers and other instances
where it makes sense (circle symbols, simple symbols with dash patterns
and so on) ASAP. I also will enable image cache use in the most simple
case which may help performance a bit.
Note, I hope to do away with 3) (there is a bug filed) but can't yet
because of a problem in the image merging code in mapgd.c (not mine old
code for a change).
Steve
