Fuzzy brushes...
Ed McNierney ed at TOPOZONE.COM
Wed Dec 14 11:28:27 EST 2005
Steve -
You're off to a good start!  I've only had a quick look, but lines seem
just fine so far (simple lines).  There are two problems with polygon
outlines:
1. The color is always white.
2. The outline line is wider (thicker) than a line symbol with the same
WIDTH setting.
But regular lines seem to have no trouble.  FYI, this is using gd-2.0.33
on Linux.
	- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: UMN MapServer Developers List [mailto:MAPSERVER-DEV at LISTS.UMN.EDU]
On Behalf Of Steve Lime
Sent: Wednesday, December 14, 2005 10:18 AM
To: MAPSERVER-DEV at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-DEV] Fuzzy brushes...
Remember it is only available for the moment in the simple case
mentioned below. I will make more generally available tonite.
Steve
>>> "Ed McNierney" <ed at topozone.com> 12/14/05 6:32 AM >>>
Steve -
I had been meaning to offer to do some testing; thanks for the post.
I'll download and take a look today.
	- Ed
Ed McNierney
Phone: +1 (978) 251-4242
Fax: +1 (978) 251-1396
ed at topozone.com
Sent: Wednesday, December 14, 2005 1:05 AM
Subject: [UMN_MAPSERVER-DEV] Fuzzy brushes...
In case anyone would like to test I have hooked up the fuzzy brush
generator in mapgd.c for the most trivial line drawing case (no symbol
defined). To use:
1) define a 24-bit output format, IMAGETYPE 'png24' works nicely
2) define a simple style definition for a line layer (or polygon
outline) like so:
  STYLE
    WIDTH 3
    COLOR 255 0 0
    ANTIALIAS TRUE
  END
3) set TRANSPARENCY ALPHA to enable alpha blending
Caveats:
 - brushes need to be odd sized. That requirement is enforced in the
brush builder which detects even sized requests and rounds up. Symbol
scaling should work just fine.
 - you'll notice that the line "fades" in at the start which is due to
the  transparent nature of the brush. Adjusting the default "hardness"
may minimize that.
That should do it. I will enable for circles layers and other instances
where it makes sense (circle symbols, simple symbols with dash patterns
and so on) ASAP. I also will enable image cache use in the most simple
case which may help performance a bit.
Note, I hope to do away with 3) (there is a bug filed) but can't yet
because of a problem in the image merging code in mapgd.c (not mine old
code for a change).
Steve
