Revised 4.8 release plan
Pericles S. Nacionales
naci0002 at UMN.EDU
Thu Dec 15 14:26:55 EST 2005
Looking deeper into this, it looks like the error goes back to version 4.6.0.
The keyword ANTIALIAS within the STYLE object causes the problem for me. I
don't get segfaults if I comment them out. This could be my system though.
I'll have to run the test on another machine.
By the way, Steve, I'm using the demo we created for the GISLIS conference.
I'm attaching the modified mapfile and template so you can test and see if
you get segfaults.
-Perry
On Thursday 15 December 2005 11:02, Ed McNierney wrote:
> Steve -
> I'm just about to test your new code from last night, but I used the
> same syntax Perry's reporting and I had no problem.
> - Ed
> -----Original Message-----
> From: UMN MapServer Developers List [mailto:MAPSERVER-DEV at LISTS.UMN.EDU]
> On Behalf Of Steve Lime
> Sent: Thursday, December 15, 2005 12:01 PM
> To: MAPSERVER-DEV at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-DEV] Revised 4.8 release plan
> This new code really shouldn't impact that style definition. I have to
> look into it though.
> Did that work prior to the new addition?
> Steve
> >>> "Pericles S. Nacionales" <naci0002 at umn.edu> 12/15/05 10:07 AM >>>
> Steve,
> LAYER
> TYPE POLYGON
> TRANSPARENCY ALPHA
> CLASS
> STYLE
> COLOR 128 128 128
> ANTIALIAS TRUE # <-- this causes a segfault
> END
> END
> When the ANTIALIAS keyword is added in the same style used to define
> polygon fill, a segfault occurs. Is this supposed to work or should an
> error be generated for this?
> -Perry
> On Wednesday 14 December 2005 22:45, Steve Lime wrote:
> > Hi Guys: I've made progress and committed a fix for the bug Ed found
> > with polygon outlines tonite so basic fuzzy brushes work pretty
> > nicely. That said, I really think we should have a beta3 and release
> > the first week in January. We should get good feedback with that new
> > feature so "beta" status makes sense. Besides getting these brushes in
> > the right spots, I'd like to try and figure out this crash Sean is
> > seeing with free'ing dynamically created styles, plus I have one other
> > bug to fix with rotating pixmap symbols.
> > Just my opinion.
> > Steve
> > >>> Daniel Morissette <dmorissette at DMSOLUTIONS.CA> 12/14/05 8:56 AM
> > Steve Lime wrote:
> > > Why don't you give me until tomorrow evening and I'll report back.
> > Sounds good then. We'll wait to hear back from you.
> > Daniel
> Conservation Biology Program
> University of Minnesota
> e-mail: naci0002 at umn.edu
Type: text/x-java
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20051215/1167aabc/mapfile.bin
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20051215/1167aabc/template.html
