geometry and projection with WFS
Steve Lime
steve.lime at DNR.STATE.MN.US
Wed Dec 21 18:52:29 EST 2005
Probably just an oversite. I'll try and address tonite before rc1...
Steve
>>> Yewondwossen Assefa <assefa at DMSOLUTIONS.CA> 12/21/05 1:15 PM >>>
From what I can see the problem seems to be that the gml code assumes
that when a shape object is projected from layer to map, the shape bound
in the object in also reprojected. It uses the function msProjectShape.
This function does not reporject the bound. I do not know why. I added
locally a call to msProjectRect(in, out, &shape->bounds); and It seems
to solve the problem. Is the bound always valid, are there reasons not
to reproject the bounds ?
Bug http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1586 has been
entred on this.
Later,
Kralidis,Tom [Burlington] wrote:
>Hi,
>We're serving a WFS of data natively in EPSG:42304. We would like to
>serve as EPSG:4326. We have set MAP/WEB/METADATA/"wfs_srs" "EPSG:4326".
>When invoking a GetFeature request:
>http://devgeo.cciw.ca/cgi-bin/mapserv/kyw?VERSION=1.0.0&SERVICE=WFS&REQU
>EST=GetFeature&TYPENAME=canadwshed&Filter=<Filter><DWithin><PropertyName
>>Geometry</PropertyName><gml:Point><gml:coordinates>-65.471193,45.429475
></gml:coordinates></gml:Point><Distance%20units='deg'>0</Distance></DWit
>hin></Filter>&
>...the feature is provided in EPSG:4326 as set in the mapfile, however
>gml:featureMember/kyw:canadwshed/gml:boundedBy returns the bounded areas
>in the native coordinates. However,
>gml:featureMember/kyw:canadwshed/gml:boundedBy/gml:Box/@srsName returns
>EPSG:4326.
>Could it be that mapgml.c is not reprojecting the boundedBy coordinates
>at the layer level? It is doing so for the geometry of the feature, as
>well as the boundedBy of the response.
>..Tom
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
