WFS GetFeature response global bounding box issue
Steve Lime
steve.lime at DNR.STATE.MN.US
Fri Dec 30 11:36:52 EST 2005
I figured you would! Thanks for testing. I'll commit tonite.
Steve
>>> "Kralidis,Tom [Burlington]" <Tom.Kralidis at EC.GC.CA> 12/29/05 2:39 PM >>>
So I was feeling adventurous :)
I made the changes to mapquery.c, make clean, ./configure, make.
When invoking the request again:
http://devgeo.cciw.ca/cgi-bin/mapserv/kyw?VERSION=1.0.0&SERVICE=WFS&REQU
EST=GetFeature&outputFormat=GML3&TYPENAME=canadwscssda&Filter=%3CFilter%
3E%3CPropertyIsEqualTo%3E%3CPropertyName%3EWSCSDA%3C/PropertyName%3E%3CL
iteral%3E01B%3C/Literal%3E%3C/PropertyIsEqualTo%3E%3C/FILTER%3E&
...looks like that did the trick.
Thanks Steve -- once again, this is what I love about open source
software!
Looking forward to a formal commit.
..Tom
> -----Original Message-----
> From: UMN MapServer Developers List
> [mailto:MAPSERVER-DEV at LISTS.UMN.EDU] On Behalf Of Steve Lime
> Sent: Thursday, December 29, 2005 2:20 PM
> To: MAPSERVER-DEV at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-DEV] WFS GetFeature response
> I gotta feeling I know what's wrong. Are you using that
> latest code? That change in mapproject.c changed things so
> that the bounds of the projected shape are recomputed after
> projection. Previously that wasn't the case. Prior to that
> the shape and its bounds could be in different projections.
> The result set merges all those bounds into one layer bbox,
> but again, in previous versions that box would have been in
> the native projection of the layer NOT the main map
> projection. That has changed.
> If you are feeling adventurous try editing mapquery.c,
> starting at line 1168 in the function
> msGetQueryResultBounds() and remove the 4 lines starting with:
> #ifdef USE_PROJ
> and ending with:
> #endif
> The projection would not be necessary since it would already
> have done. What is happening is that we end up projecting
> twice- bad news.
> Let me know if that helps and I'll make the change before
> releasing 4.8 (which I think should wait until Monday).
> Steve
> 12/29/05 9:20 AM
> Anyone have any updates / pointers w.r.t. this issue?
> ..Tom
> > Hi,
> > Against latest CVS, if I invoke the following OGC:WFS
> > GetFeature w/ Filter request:
> E=WFS&REQUEST=GetFeature&outputFormat=GML3&TYPENAME=canadwscss
> da&Filter=
> %3CFilter%3E%3CPropertyIsEqualTo%3E%3CPropertyName%3EWSCSDA%3C
> /PropertyN
> ame%3E%3CLiteral%3E01B%3C/Literal%3E%3C/PropertyIsEqualTo%3E%3
> C/FILTER%3
> E
> I receive a response back with results as expected.
> When inspecting /msFeatureCollection/gml:boundedBy, the
> actual values are not representative of the entire set of
> results. Infact, they're way off. The gml:boundedBy chunk
> WITHIN each gml:featureMember seem to be fine.
> I notice mapproject.c was changed on 23/12/2005, so I'm not
> sure if this had any effect.
> Cheers
> ..Tom
