Is the MapServer code supposed to be ANSI C?
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Tue Feb 1 12:00:53 EST 2005
Agreed. We might want to add -ansi -pedantic to our compile settings in
Makefile as well.
..Tom
> -----Original Message-----
> From: UMN MapServer Developers List
> [mailto:MAPSERVER-DEV at LISTS.UMN.EDU] On Behalf Of Steve Lime
> Sent: Tuesday, 01 February, 2005 11:51
> To: MAPSERVER-DEV at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-DEV] Is the MapServer code
> Hi Petter: Certainly intended to send to the whole list, slip
> of the mouse (CC'ing now). After doing a bit of reading after
> your initial posting I agree that that ANSI C C89 makes the
> most logical target at this point in time.
> Steve
> >>> Petter Reinholdtsen <pere at hungry.com> 01/31/05 4:23 PM >>>
> [Steve Lime]
> > Petter: A target has never really been discussed. I think many
> > developers took some of their cues (stylewise) from my
> original code,
> > which in some places may be 7 or 8 years old (not too much of that
> > left, but there is some). I shot for ANSI C but never
> explicitly set
> > that as a design goal.
> Well, unless one agrees on the specification, it is hard to
> know if the code is correct or not. Given a specification,
> one can decide if the code or the compiler behaves correctly.
> Without a specification, it is much harder.
> And the question about C89 or C99 have practical
> implications. Should code like this be allowed:
> int foo; // C99 comment, illegal in C89.
> char a[foo]; /* varsize array, illegal in C89 */
> char c = -1; /* C89 allow both signed and unsigned char type */
> if (c > 0) /* undefined behavior for C89, well defined for C99 */
> printf("negative c\n");
> Because of these and other issues, I would prefer to know if
> the code is supposed to be ANSI C or not, and if it is
> supposed to be ANSI C, which version of ANSI C it is supposed
> to be using.
> I would prefer the code to follow ANSI C using the C89
> specification, because several of the compilers I am using
> are not able to handle the C99 specification yet.
> (Btw, why did you send your answer only to me? I'm happy to
> discuss this on the public list. :)
