non-spatial query optimization
Steve Lime
steve.lime at DNR.STATE.MN.US
Tue Feb 1 19:55:26 EST 2005
Ok with me...
>>> Frank Warmerdam <warmerdam at POBOX.COM> 02/01/05 4:10 PM >>>
Folks,
Paul Ramsey pointed out that the current msSHPWhichShapes() function
requires
a search rectangle. This means that any sort of query against a feature
datasource in MapServer ends up having a bounding rectangle whether it
is
needed or not. This can result in substantial complication and extra
cost
in the underlying datastores to apply the spatial filter.
For instance, in an RDBMS it results in a much more complex query that
may
end up being optimized poorly. In OGR having a spatial filter often
screws
up optimizations in the underlying datasources as well.
I propose to change msSHPWhichShapes() to take a pointer to a rectObj,
instead of passing in a rectObj by value. If the pointer is NULL it
will
be interpreted as meaning there is no spatial component to be tested.
All the feature store providers will need to be updated accordingly,
which
I am willing to do for the more straight forward ones (ie. Shapefiles,
OGR,
PostGIS). The other provider maintainer would need to implement this
themselves, though I would make a first pass through making the code
return
an error if a NULL rect was passed into these providers.
Are there any objections to me making such a change in MapServer 4.5?
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | Geospatial Programmer for Rent
