mappostgis.c and PostGIS 1.0.0
Paul Ramsey
pramsey at REFRACTIONS.NET
Thu Feb 3 13:44:12 EST 2005
Has anyone tried mapserver as a WFS against PostGIS of any version? I
have been trying to figure out how the <Filter>s are applied against
database backends, perhaps something I can do as I loll about in bed
this afternoon, but it was not immediately clear to me.
That said, I guess you were also having problems with WMS, right Tom?
P
Kralidis,Tom [Burlington] wrote:
> I've been trying for between mapserver-users and postgis-users to figure
> this one out (I'm starting to feel like one of thoese guys).
> Has anyone successfully tested MapServer CVS with PostGIS 1.0.0RC2? I'm
> trying to do this, and after much debugging and testing, it looks like
> the MapServer code needs to be updated for the new PostGIS dist.
> Test:
> Here is what's been done successfully:
> - configure PostGIS DB
> - insert sample data
> - fetch sample data via psql
> - configure mapfile to connect with the following:
> CONNECTIONTYPE postgis
> CONNECTION "user=postgres dbname=devgeodb"
> DATA "the_geom from service_resources"
> - Run OGC:WFS GetCapabilities
> - Run OGC:WFS DescribeFeatureType
> - response as expected, I can see the table schema via XML output
> ...when I go to run GetFeature, no data comes back. DescribeFeatureType
> works, so I know the connection is ok. I'm wondering if the data
> fetching bindings in PostGIS 1.0.0RC2 have changed, and if MapServer
> needs to update these.
> I'm miffed.
> ..Tom
