Automatic coverage testing of mapserv?
Frank Warmerdam
fwarmerdam at GMAIL.COM
Sat Feb 5 23:07:02 EST 2005
On Sat, 5 Feb 2005 23:20:31 +0100, Petter Reinholdtsen <pere at hungry.com> wrote:
> [Frank Warmerdam]
> > In addition to Sean's mapscript based unit test,
> Where is this? Are you talking about the stuff in mapserver/tests/?
Petter,
Sean already mentioned where his unit tests are.
I am not honestly sure what the mapserver/tests directory
is for.
> This look like a very good starting point. I'm investigating it now.
> One thing that surprised me was the fact that you seem to be using a
> home made test suite system instead of using the official one included
> in python. Why is this? Unless you have a very good reason, I
> suggest we rewrite it to use the unittest python module,
> <URL:http://docs.python.org/lib/module-unittest.html>. This will give
> us the system to run all tests at once and give a summary at the end
> of all these tests.
I am not interested in changing it without a fairly compelling
reason. Hopefully we will have a chance to meet and share
a few beers at MUM3, and I can do my full "grumpy old man"
routine where I berate you for wanting to change everything.
Sort of like I did with Sean last year.
I believe that Sean has used the python unittest stuff.
> > Rather than starting yet another completely different test methology
> > I would encourage you to look at adding into msauotest. I'm sure a
> > "mapserv QUERY_STRING=... " style test would fit into it quite
> > naturally, and I would be willing to cooperate on it.
> Yes, this look like a better starting point that the mapserver/tests/
> scripts, and I will start here. I'll start by trying to understand
> the current tests, and see how much code coverage they provide.
> This patch will make it easier to enable coverage testing using a new
> --enable-coverage configure flag.
I don't know if someone else is picking up on all your patches, but
I'm not applying them. I will apply any that seem sensible to me if
they are submitted properly through bugzilla and end up assigned
to me. That is our methodology.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
