mappostgis.c and PostGIS 1.0.0
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Sun Feb 6 13:55:49 EST 2005
Update:
There was an issue in the latest patch applied to mappostgis.c which
caused these issues. Paul and co. have rolled back the patch and things
work as expected.
We did find some other interesting issues along the way (to be addressed
via Bugzilla).
..Tom
> -----Original Message-----
> From: UMN MapServer Developers List
> [mailto:MAPSERVER-DEV at LISTS.UMN.EDU] On Behalf Of
> Sent: Thursday, 03 February, 2005 14:34
> To: MAPSERVER-DEV at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-DEV] mappostgis.c and PostGIS 1.0.0
> Hi,
> Yes, WMS doesn't work either for me.
> MapServer CVS
> PostGIS 1.0.0RC2
> Linux Fedora Core
> ..Tom
> > [mailto:MAPSERVER-DEV at LISTS.UMN.EDU] On Behalf Of Paul Ramsey
> > Sent: Thursday, 03 February, 2005 13:44
> > Has anyone tried mapserver as a WFS against PostGIS of any
> > version? I have been trying to figure out how the <Filter>s
> > are applied against database backends, perhaps something I
> > can do as I loll about in bed this afternoon, but it was not
> > immediately clear to me.
> > That said, I guess you were also having problems with WMS,
> right Tom?
> > P
> > Kralidis,Tom [Burlington] wrote:
> > > I've been trying for between mapserver-users and postgis-users to
> > > figure this one out (I'm starting to feel like one of
> thoese guys).
> > > Has anyone successfully tested MapServer CVS with PostGIS
> > 1.0.0RC2?
> > > I'm trying to do this, and after much debugging and
> > testing, it looks
> > > like the MapServer code needs to be updated for the new
> > PostGIS dist.
> > > Test:
> > > Here is what's been done successfully:
> > > - configure PostGIS DB
> > > - insert sample data
> > > - fetch sample data via psql
> > > - configure mapfile to connect with the following:
> > > CONNECTIONTYPE postgis
> > > CONNECTION "user=postgres dbname=devgeodb"
> > > DATA "the_geom from service_resources"
> > > - Run OGC:WFS GetCapabilities
> > > - Run OGC:WFS DescribeFeatureType
> > > - response as expected, I can see the table schema via XML output
> > > ...when I go to run GetFeature, no data comes back.
> > > DescribeFeatureType works, so I know the connection is ok. I'm
> > > wondering if the data fetching bindings in PostGIS 1.0.0RC2 have
> > > changed, and if MapServer needs to update these.
> > > I'm miffed.
> > > ..Tom
