corrected version of shp2mysql.pl
    Gregor Mosheh
    stigmata_blackangel at YAHOO.COM
    Wed Feb  9 23:39:59 EST 2005
I posted to mapserver-users yesterday that
shp2mysql.pl was not working correctly. I have
corrected the problem in shp2mysql.pl, and the
corrected file is attached. I also sent a copy to
Atilla Csipa. I think that, if your testing confirms
that my changes were a good thing, it would make a
good update to the next MapServer release.
The problem I described:
Running the program gave a "not an array reference at
line 235" error. This was after the tables had been
created, while parsing the first shape in the
shapefile.
This problem existed with different shapefiles of
various geometry types.
Analysis:
Iteration through the shape's attributes was using a
numeric index through an arrayref, and the attributes
are stored in a hashref keyed by the attribute name.
Thus, not an array reference.
I could only guess that some old version of
Geo::Shapelib used indexes, but Geo::Shapelib 0.12 and
0.13 use a hash.
Fix:
Around line 240, a simple replacement of the iteration
to instead use
@{$shape->{FieldNames}}
for iteration and
${$shape->{ShapeRecords}}[$_]{$fieldname}
for attribute fetching.
Result:
It now works, seeming properly.
The Geo::Shapelib versions available to CPAN, back to
0.09, have a FieldNames attribute and therefore this
modified shp2mysql.pl should work with those versions
of this library.
__________________________________
Do you Yahoo!?
Yahoo! Mail - You care about security. So do we.
http://promotions.yahoo.com/new_mail
#!/usr/bin/perl
# Copyright (c) 2003, Attila Csipa, Manufaktura Internet Inzenjering doo
# Gregor Mosheh, Feb 2005 - line 235, fixed the iteration to use
#                           attributes' names instead of index number
$|=1;
use DBI;
use Geo::Shapelib qw/:all/;
#use Shape qw/:all/; # use this if you have an older shapelib version installed and the above line fails (also change line 29)
$dbname = "gisdata";
$host = "localhost";
$dbuser = "gisdata";
$dbpass = "password";
$mac = 0;       # this is not a mac
$ENDIAN = 1;    # 0 = big endian - mac, 1 = little endian - intel
# --- do not edit below this line
die "Configure database parameters on the beginning of this script file\n" if $dbname eq "changeme";
$dbh = DBI->connect("DBI:mysql:$dbname:$host:3306",$dbuser,$dbpass) || die $DBI::errstr ;
$dbh->{RaiseError} = 1;
die "Usage: shp2mysql shpname\n\nwhere shpname is the name (with path) to the base name of the shape file (do not include file name extensions !)\n" unless $ARGV[0];
die "Shapefile $ARGV[0] not found !" unless -f "$ARGV[0].shp";
$shape = new Geo::Shapelib $ARGV[0];
#$shape = new Shape $ARGV[0];
$WKB_POINT = 1;
$WKB_LINESTRING = 2;
$WKB_POLYGON = 3;
$WKB_MULTIPOINT = 4;
$WKB_MULTILINESTRING = 5;
$WKB_MULTIPOLYGON = 6;
$WKB_GEOMETRYCOLLECTION = 7;
sub query
    my $sth = $dbh->prepare(shift) or die "DBI error $!";
    $sth->execute or die "DBI error $!";
    return $sth;
sub rect
    my ($x0, $y0, $x1, $y1) = @_;
    my $minx = $x0 <  $x1 ? $x0 : $x1;
    my $maxx = $x0 >= $x1 ? $x0 : $x1;
    my $miny = $y0 <  $y1 ? $y0 : $y1;
    my $maxy = $y0 >= $y1 ? $y0 : $y1;
    return ($minx, $miny, $maxx, $maxy);
$dbh->do("CREATE TABLE IF NOT EXISTS GEOMETRY_COLUMNS (
      F_TABLE_CATALOG varchar(100) NOT NULL default '',
      F_TABLE_SCHEMA varchar(100) NOT NULL default '',
      F_TABLE_NAME varchar(100) NOT NULL default '',
      F_GEOMETRY_COLUMN varchar(100) NOT NULL default '',
      G_TABLE_CATALOG varchar(100) NOT NULL default '',
      G_TABLE_SCHEMA varchar(100) NOT NULL default '',
      G_TABLE_NAME varchar(100) NOT NULL default '',
      STORAGE_TYPE int(11) NOT NULL default '0',
      GEOMETRY_TYPE int(11) NOT NULL default '0',
      COORD_DIMENSION int(11) NOT NULL default '0',
      MAX_PPR int(11) NOT NULL default '0',
      SRID int(11) NOT NULL default '0',
      PRIMARY KEY  (F_TABLE_CATALOG,F_TABLE_SCHEMA,F_TABLE_NAME,F_GEOMETRY_COLUMN)
    ) TYPE=MyISAM;");
$dbh->do("CREATE TABLE IF NOT EXISTS SPATIAL_REF_SYS (
      AUTH_NAME varchar(255) default NULL,
      AUTH_SRID int(11) default NULL,
      SRTEXT varchar(255) default NULL,
      PRIMARY KEY  (SRID)
    ) TYPE=MyISAM;");
%sqlcreate = ( point => "  id int(11) NOT NULL auto_increment,
  layer int(11) NOT NULL default '0',
  x1 double default NULL,
  y1 double default NULL,
  x2 double default NULL,
  y2 double default NULL,
  vertices int(11) NOT NULL default '1',
  GID int(11) NOT NULL,
  PRIMARY KEY  (id),
  FOREIGN KEY GID(GID, x1, y1, x2, y2) REFERENCES geometry_point_num (GID),
  KEY layer (layer),
  KEY turbo (x2,y2,x1,y1)",
                arc => "  id int(11) NOT NULL auto_increment,
  PRIMARY KEY  (id),
  FOREIGN KEY GID(GID, x1, y1, x2, y2) REFERENCES geometry_arc_num (GID),
  KEY layer (layer),
                polygon => "  id int(11) NOT NULL auto_increment,
  PRIMARY KEY  (id),
  FOREIGN KEY GID(GID, x1, y1, x2, y2) REFERENCES geometry_polygon_num (GID),
  KEY layer (layer),
                annotation => "  id int(11) NOT NULL auto_increment,
  angle double default '0.0',
  size int not null default '10',
  txt VARCHAR(255) NOT NULL default '',
  PRIMARY KEY  (id),
  FOREIGN KEY GID(GID, x1, y1, x2, y2) REFERENCES geometry_annotation_num (GID),
  KEY layer (layer),
                num => "  GID INTEGER NOT NULL,
  ESEQ INTEGER NOT NULL,
  ETYPE INTEGER NOT NULL,
  X1 double default NULL,
  Y1 double default NULL,
  X2 double default NULL,
  Y2 double default NULL,
  CONSTRAINT GID_PK PRIMARY KEY (GID, ESEQ, SEQ),
  KEY x (X1,Y1)",
                bin => "  GID INTEGER NOT NULL,
  XMIN double default NULL,
  YMIN double default NULL,
  XMAX double default NULL,
  YMAX double default NULL,
  WKB_GEOMETRY BLOB,
  KEY (GID),
  KEY x (XMIN,YMIN,XMAX,YMAX)"
$sqlcreate{'3'} = $sqlcreate{'arc'};
$sqlcreate{'line'} = $sqlcreate{'arc'};
sub mklayer
    my ($sh, $type, $add) = @_;
          $sh =~ tr/-/_/;
    #print "$sh/$type ($sqlcreate{$type})\n";
        $dbh->do("drop table if exists $sh");
        $dbh->do("drop table if exists ${sh}_num");
        $dbh->do("drop table if exists ${sh}_bin");
        $dbh->do("create table if not exists $sh ($sqlcreate{$type} $add)");
        $dbh->do("create table if not exists ${sh}_num ($sqlcreate{num})");
        $dbh->do("create table if not exists ${sh}_bin ($sqlcreate{bin})");
        $dbh->do("delete from GEOMETRY_COLUMNS where F_TABLE_NAME = ".$dbh->quote($sh));
        $dbh->do("insert into GEOMETRY_COLUMNS
        (F_TABLE_CATALOG,F_TABLE_SCHEMA,F_TABLE_NAME,F_GEOMETRY_COLUMN,G_TABLE_CATALOG,G_TABLE_SCHEMA,G_TABLE_NAME,STORAGE_TYPE,GEOMETRY_TYPE,COORD_DIMENSION,MAX_PPR,SRID)
        values ('$dbname', '', ".$dbh->quote($sh).", 'GID', '$dbname', '', ".$dbh->quote("${sh}_bin").", 1, '$gtype{$type}', 2, 2, 0)");
sub wkb
    $int = $mac ? "N" : "V";
    my ($poly, $end, $wkbt)= (shift, shift, shift);
    my $wkb = pack("C$int$int", $end, $WKB_GEOMETRYCOLLECTION, 1);
    $wkb .= pack("C$int", $end, $wkbt);
    my $nr = shift;
    if ($poly){
        $wkb .= pack("$int", $nr);
    while ($nr -- > 0){
        my $pts = shift;
        if ($wkbt != $WKB_POINT){
            $wkb .= pack("$int", $pts);
        $double = "";;
        for (my $i=0; $i<$pts; $i++){
            $double = pack("dd", shift, shift);
            if ($mac){
                @o = unpack("CCCCCCCCCCCCCCCC", $double);
                $double = pack("CCCCCCCCCCCCCCCC", $o[7],$o[6],$o[5],$o[4],$o[3],$o[2],$o[1],$o[0],$o[15],$o[14],$o[13],$o[12],$o[11],$o[10],$o[9],$o[8]);
            $wkb .= $double;
    return $wkb;
@tmp = split(/\//, $ARGV[0]);
$sh = pop @tmp;
undef $fields;
undef @field;
undef $appendvars;
undef $vars;
#$shape->{FieldTypes} = ['Integer'];
for (@{$shape->{FieldNames}}){
        $fields .= ", f_$_ VARCHAR(255) NOT NULL DEFAULT ''";
        push @field, "f_$_";
        $appendvars .= ", f_$_ ";
        $vars++;
if ($shape->{Shapetype} eq POINT){
        mklayer($sh , 'point', $fields);
} elsif ($shape->{Shapetype} eq LINE or $shape->{Shapetype} eq 3){
        mklayer($sh , 'line', $fields);
} elsif ($shape->{Shapetype} eq ARC){
        mklayer($sh , 'arc', $fields);
} elsif ($shape->{Shapetype} eq POLYGON){
        mklayer($sh , 'polygon', $fields);
for (0..@{$shape->{Shapes}}-1){
        undef $appenddata;
        #for ($v = 0; $v < $vars; $v++){
        #       $appenddata .= ", ".$dbh->quote(${$shape->{ShapeRecords}}[$_][$v]);
        foreach my $fieldname (@{$shape->{FieldNames}}) {
                $appenddata .= ", ".$dbh->quote(${$shape->{ShapeRecords}}[$_]{$fieldname});
                #print $dbh->quote(${$shape->{ShapeRecords}}[$_]{$fieldname});
        $vrt=-1;
        while (${$shape->{Shapes}}[$_]{Vertices}[++$vrt][0] ne undef){
         $gid++;
         $feat++;
         undef %object;
                $object{x0} = ${$shape->{Shapes}}[$_]{Vertices}[$vrt-1][0];
                $object{y0} = ${$shape->{Shapes}}[$_]{Vertices}[$vrt-1][1];
                $object{x1} = ${$shape->{Shapes}}[$_]{Vertices}[$vrt][0];
                $object{y1} = ${$shape->{Shapes}}[$_]{Vertices}[$vrt][1];
                next unless $object{x0};
# line
            print "-";
            $dbh->do("insert into ${sh}_num (GID, ESEQ, SEQ, ETYPE, X1, Y1, X2, Y2) values ('$gid', 1, 1, 2, '$object{x0}','$object{y0}','$object{x1}','$object{y1}')");
            $string =  wkb(0, $ENDIAN, $WKB_LINESTRING, 1, 2,$object{x0}, $object{y0}, $object{x1}, $object{y1});
            my $sth = $dbh->prepare("insert into ${sh}_bin (GID, XMIN, YMIN, XMAX, YMAX, WKB_GEOMETRY) values ('$gid', '$object{x0}','$object{y0}','$object{x1}','$object{y1}', ? )");
             $sth->execute($string);
            $sth->finish;
            ($minx, $miny, $maxx, $maxy) = rect($object{x0}, $object{y0}, $object{x1}, $object{y1});
            $dbh->do("insert into $sh (id, layer, vertices, GID, x1, y1, x2, y2 $appendvars) values ('$feat', '$layer{$sh}', 1, '$gid', '$minx', '$miny', '$maxx', '$maxy' $appenddata)") if $vrt eq 0;
# line
            print "-";
            $sth->finish;
         } elsif ($shape->{Shapetype} eq POINT){
                $object{x0} = ${$shape->{Shapes}}[$_]{Vertices}[$vrt][0];
                $object{y0} = ${$shape->{Shapes}}[$_]{Vertices}[$vrt][1];
# point
            print ".";
            $dbh->do("insert into ${sh}_num (GID, ESEQ, SEQ, ETYPE, X1, Y1, X2, Y2) values ('$gid', 1, 1, 1, '$object{x0}','$object{y0}','0','0')");
            my $sth = $dbh->prepare("insert into ${sh}_bin (GID, XMIN, YMIN, XMAX, YMAX, WKB_GEOMETRY) values ('$gid', '$object{x0}','$object{y0}','$object{x0}','$object{y0}', ?)");
            $sth->execute(wkb(0, $ENDIAN, $WKB_POINT, 1, 1,$object{x0}, $object{y0}));
            $sth->finish;
            $dbh->do("insert into $sh (id, layer, vertices, GID, x1, y1, x2, y2 $appendvars) values ('$feat', '$layer{$sh}', 1, '$gid', '$object{x0}', '$object{y0}', '$object{x0}', '$object{y0}' $appenddata)");
# poly
            print "O";
                @vertex = @{${$shape->{Shapes}}[$_]{Vertices}};
            ($minx, $miny, $maxx, $maxy) = rect($vertex[0][0], $vertex[0][1], $vertex[0][0], $vertex[0][1]);
            $eseq=1;
            push @vertices, $vertex[0][0], $vertex[0][1];
            for ($v = 1; $v<=$#vertex; $v++) {
                $dbh->do("insert into ${sh}_num (GID, ESEQ, SEQ, ETYPE, X1, Y1, X2, Y2) values ('$gid', 1, $v, 3, '$vertex[$v -1][0]','$vertex[$v -1][1]', '$vertex[$v][0]','$vertex[$v][1]')");
                push @vertices, $vertex[$v][0], $vertex[$v][1];
                $maxx = $vertex[$v][0] if ($vertex[$v][0] > $maxx);
                $minx = $vertex[$v][0] if ($vertex[$v][0] < $minx);
                $maxy = $vertex[$v][1] if ($vertex[$v][1] > $maxy);
                $miny = $vertex[$v][1] if ($vertex[$v][1] < $miny);
#                $dbh->do("insert into vertex (shape,x,y,z) values ('$shape_id','$vertex[$v][0]','$vertex[$v][1]','0')");
            my $sth = $dbh->prepare("insert into ${sh}_bin (GID, XMIN, YMIN, XMAX, YMAX, WKB_GEOMETRY) values ('$gid', '$minx','$miny','$maxx','$maxy', ?)");
            $sth->execute(wkb(1, $ENDIAN, $WKB_POLYGON, 1, $#vertex+1, @vertices));
            $sth->finish;
            undef @vertices;
            $dbh->do("insert into $sh (id, layer, vertices, GID, x1, y1, x2, y2 $appendvars) values ('$feat', '$layer{$sh}', '$#vertex', '$gid', '$minx', '$miny', '$maxx', '$maxy' $appenddata)") if $vrt eq 0;
            $vrt = $#vertex;
print "\n";
