ASP wrapper and HTTP GET requests
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Tue Feb 22 22:12:37 EST 2005
Thanks for the info.
Bug 1253 does not have a template problem. What's happening is that the
POST request is sent to ASP script, which passes as a GET request with
no arguments.
Can someone try this out and verify this works? Also see comment line
below in the code:
Server.ScriptTimeout = 360
Select Case Request.ServerVariables("REQUEST_METHOD")
Case "GET" strRequest = Request.QueryString
Case "POST" strRequest = Request.Form
End Select
strRequest = Request.ServerVariables("QUERY_STRING")
strURL =
"http://myserver/cgi-bin/mapserv.exe?map=C:\Inetpub\wwwroot\WMS\mymap.ma
p&" & strRequest
Dim objHTTP
Set objHTTP = Server.CreateObject("MSXML2.ServerXMLHTTP")
' will this line below work for POST requests?
objHTTP.open "GET", strURL, false
objHTTP.send ""
Response.ContentType = objHTTP.getResponseHeader("content-type")
Response.BinaryWrite objHTTP.responseBody
Set objHTTP = Nothing
..Tom
> -----Original Message-----
> From: UMN MapServer Developers List
> [mailto:MAPSERVER-DEV at LISTS.UMN.EDU] On Behalf Of Jerry Pisk
> Sent: Tuesday, 22 February, 2005 20:46
> To: MAPSERVER-DEV at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-DEV] ASP wrapper and HTTP GET requests
> You can easily change that sample ASP page to support POST
> requests, replace the query string read with this:
> Case Else ' Handle other methods here
> End Select
> The problem in bug 1253 is not related to this though, it's
> caused by a missing template in a mapfile as far as I can tell.
> Jerry Pisk
> On Tue, 22 Feb 2005 18:27:57 -0500, Kralidis,Tom [Burlington]
> <Tom.Kralidis at ec.gc.ca> wrote:
> > Hi,
> > There seems to be a problem with the ASP wrapper example
> provided for
> > hiding the mapfile from:
> http://mapserver.gis.umn.edu/doc44/wms-server-howto.html#onlineresourc
> > eu
> > rl
> > I've filed a bug against this:
> > http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1253
> > The wrapper script doesn't support POST requests.
> > Are there any ASP gurus out there who can tweak the example
> so that it
> > can recognize when a POST request comes in and pass it as such?
> > Thanks
> > ..Tom
