python mapscript processLegendTemplate()
Sean Gillies
sgillies at FRII.COM
Wed Jan 12 15:12:40 EST 2005
On Jan 12, 2005, at 11:02 AM, Vincent Schut wrote:
> Hi all,
> is map.processLegendTemplate() in python mapscript (cvs upped today)
> supposed to work? Or are the typemaps not yet enabled?
> I don't seem to be able to get it to work, actually, and would like to
> know if this is my fault :-)
No, Vincent, not your fault. As far as I know, the template processing
methods in mapscript have never worked. I believe (correct me if I'm
wrong) that they were added to the SWIG file based on a
misunderstanding of SWIG's built-in type mapping.
> From the source I see that I am supposed to supply a names, a values
> and a numItems paramter. What are these? If I supply (None, None, 0) I
> get the following error in apache's errorlog:
> [Wed Jan 12 18:54:26 2005] [error] [client 127.0.0.1] PythonHandler
> mod_python.publisher: File
> "/usr/lib/python2.3/site-packages/mapscript.py", line 902, in
> processLegendTemplate\n def processLegendTemplate(*args): return
> _mapscript.mapObj_processLegendTemplate(*args)
> mod_python.publisher: MapServerError: msFreeHashItems(): Hash table
> error.Can't free NULL table\nmsFreeHashItems(): Hash table error. Can't
> free NULL table
> If I supply any other thing than None's as first/second argument, I get
> complaints about the argument type (should be pointer and/or p_p_char).
> Btw, I saw an item in the bugzilla about a problem that looked similar,
> but was about java mapscript (bug 1128).
> Any suggestions are welcome! I would really like to have html legends
> working in python mapscript...
> Cheers,
> Vincent.
If you can commit a working patch, I'll merge it into CVS for you. I
am also happy to give you pointers to better templating systems, but
can't spare the time to write the typemaps for template processing.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
