[PATCH] Typo in mapwms.c (and lots of warnings)
Frank Warmerdam
fwarmerdam at GMAIL.COM
Mon Jan 24 10:03:52 EST 2005
On Mon, 24 Jan 2005 09:46:51 +0100, Petter Reinholdtsen <pere at hungry.com> wrote:
> I recently started looking at the mapserver source, and discovered
> that it is compiled using very few warning flags enabled. When
> enabling more warnings, I found several bugs. This is about one of
> them. I use this patch to enable more warnings:
> Index: aclocal.m4
> RCS file: /data2/cvsroot/mapserver/aclocal.m4,v
> retrieving revision 1.10
> diff -u -r1.10 aclocal.m4
> --- aclocal.m4 22 Jul 2003 20:05:25 -0000 1.10
> +++ aclocal.m4 24 Jan 2005 08:37:21 -0000
> @@ -33,20 +33,21 @@
> AC_DEFUN(AC_COMPILER_WFLAGS,
> + WFLAGS="-W -Wall -Wcast-align -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wpointer-arith -Wreturn-type"
> # Remove -g from compile flags, we will add via CFG variable if
> # we need it.
> CXXFLAGS=`echo "$CXXFLAGS " | sed "s/-g //"`
> CFLAGS=`echo "$CFLAGS " | sed "s/-g //"`
> - # check for GNU compiler, and use -Wall
> + # check for GNU compiler, and use warning flags
> if test "$GCC" = "yes"; then
> - C_WFLAGS="-Wall"
> - CFLAGS="$CFLAGS -Wall"
> + C_WFLAGS="$WFLAGS"
> + CFLAGS="$CFLAGS $WFLAGS"
> AC_DEFINE(USE_GNUCC)
> fi
> if test "$GXX" = "yes"; then
> - CXX_WFLAGS="-Wall"
> - CXXFLAGS="$CXXFLAGS -Wall"
> + CXX_WFLAGS="$WFLAGS"
> + CXXFLAGS="$CXXFLAGS $WFLAGS"
> fi
> AC_SUBST(CXX_WFLAGS,$CXX_WFLAGS)
> @@ -55,16 +56,17 @@
> AC_DEFUN(AC_COMPILER_WFLAGS_DEBUG,
> # -g should already be in compile flags.
> - # check for GNU compiler, and add -Wall
> + # check for GNU compiler, and add warning flags
> - C_WFLAGS="-Wall"
> fi
> fi
> This in turn report lots and lots of potential problems in the code.
> I would like to help getting rid of all these warnings, but will need
> commends and suggestions on how to best solve them.
> One of the warnings are this one.
> mapwms.c:1959: warning: ordered comparison of pointer with integer zero
> The problem seem to be a missing index in the source, where the
> pointer to an array is compared with zero instead of the value in the
> array. This patch solve the problem. Please include it in a future
> version of mapserver.
> Index: mapwms.c
> RCS file: /data2/cvsroot/mapserver/mapwms.c,v
> retrieving revision 1.158
> diff -u -r1.158 mapwms.c
> --- mapwms.c 14 Jan 2005 05:03:01 -0000 1.158
> +++ mapwms.c 24 Jan 2005 08:38:46 -0000
> @@ -1955,7 +1958,7 @@
> //free the stuff used for nested layers
> for (i = 0; i < map->numlayers; i++)
> - if (numNestedGroups > 0)
> + if (numNestedGroups[i] > 0)
> msFreeCharArray(nestedGroups[i], numNestedGroups[i]);
Peter,
I would suggest submitting these as bugzilla reports with the patches attached.
Likewise for the sortshp.c change, and the UNUSED changes. I tried
applying the sortshp.c patch with the patch program and it didn't work.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
