[PATCH] Typo in mapwms.c (and lots of warnings)
Petter Reinholdtsen
pere at HUNGRY.COM
Mon Jan 24 18:04:05 EST 2005
[Yewondwossen Assefa]
> Thnaks. I applied the patch in main brach as well as the 4.4.x
> branch.
Thank you. Did you only apply the code fix, or did you increase the
default warning level as well?
[Frank Warmerdam]
> I would suggest submitting these as bugzilla reports with the
> patches attached. Likewise for the sortshp.c change, and the UNUSED
> changes. I tried applying the sortshp.c patch with the patch
> program and it didn't work.
I'm confused. Should I submit to bugzilla, or should I send to this
mailing list? I've been told to to both, and am not sure what is
prefered.
