msSHPReadShape and potential memory leak (and sorthshp.c)
Richard Roger
richard.roger at AGRIC.NSW.GOV.AU
Sun Jul 10 21:52:20 EDT 2005
Dear List
I have been writing a program to re-write a shapefile in a spatially
sorted order. My test file is about 1.3 GB in size and has over 4 million
polygons. My program is based on "sortshp.c" and "shptree.c" . I am
using Mapserver-4.6.0 distribution on a Sun system using Solaris 8 and
using gcc 3.4.2.
The heart of the program is a simple loop, something like
for( i=0; i<num_records; i++ ) {
msSHPReadShape( inSHP, entity[i], shape );
msSHPWriteShape( outSHP, shape );
where shape is of type shapeObj *.
As written, this loop causes the program to use about 1GB (not MB!) of
memory over and above its other demands. If a call to msFreeShape is
added, so the loop is changed to
msFreeShape( shape );
then the memory usage is only about 50MB (twenty times less).
This memory "leak" in the first loop is caused by my initially poor
understanding and use of msSHPReadShape, but I think it's a mistake others
might easily make. I think this "feature" could be avoided by the
following change :
*** replace the call to "msInitShape" in "msSHPReadShape" by a call to a
"msFreeShape".
I am not sure if "msFreeShape" would need to be modified to deal with an
entirely null shape.
I have not submitted this as a bug as I am not sure if I am using the
mapshape functions correctly.
If this change is not made to msSHPReadShape, then I'd advocate adding an
"msFreeShape" to "sorthshp.c" right after the two calls
"msSHPReadShape/msSHPWriteShape".
Regards
Richard E. Roger
Dr. R. E. Roger NSW Department of
Primary Industries
Spatial Information Officer Systems 161 Kite St
Resource Information Unit Locked Bag 21
ORANGE NSW 2800
ph: (02) 6391 3697 fax: (02) 6391 3740
This message is intended for the addressee named and may contain
confidential information. If you are not the intended recipient or
received it in error, please delete the message and notify sender. Views
expressed are those of the individual sender and are not necessarily the
views of their organisation.
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20050711/cf6002d7/attachment.html
