MapScript in Delphi
Daniel Morissette dmorissette at DMSOLUTIONS.CA
Thu Jul 14 12:01:41 EDT 2005
We've had a request to make MapScript available in Delphi. Unfortunately
SWIG doesn't support Delphi directly, but my relatively short experience
with Delphi (with the MITAB library's C API) tells me that it should be
a matter of defining a clean C API for MapScript, building that into a
DLL, and then building a corresponding .pas header file. Sounds too
simple to be true when presented this way, I'm sure there will be
issues, for instance I don't know if we could run into problems in
dealing with members of complex C structures (e.g. mapObj) from Delphi
since I don't know how far Delphi can go in modifying values inside C
structs.
I have also heard comments here and there about working on a clean C API
for the MapServer core, so perhaps this could be a good time to start
cleanining up the core as well, instead of just building another
MapScript wrapper.
If this moves ahead then I'll come up with a formal TSC proposal. For
now I'm sending this to find out if anyone has any advice to offer, or
comments/suggestions on the way they would prefer to see things being done.
Daniel
  Daniel Morissette               dmorissette at dmsolutions.ca
  DM Solutions Group              http://www.dmsolutions.ca/
