shapeObj buffer resize algorithm
Kovacs Baldvin baldvin at CS.ELTE.HU
Wed Jul 27 10:21:37 EDT 2005
Hi!
I've attached a patch that makes the msAddLines variants to use
relocate, but without introducing the manual heuristic. I think
it is the reasonable solution...
Best regards,
Baldvin Kovacs
Below are the profiling results. For every test case 100 runs
were made and the results cumulated. All of them was compiled
with -O2 -pg
1. With this patch included:
  %   cumulative   self              self     total
 time   seconds   seconds    calls  ms/call  ms/call  name
 17.79      4.67     4.67      100    46.70    46.70  msImageCopyMerge
 14.63      8.51     3.84      200    19.20    19.20  msImageInitGD
  3.85     19.46     1.01  3120400     0.00     0.00  msAddLine
2. With the bufsize *= 2 heuristic:
 18.69      4.87     4.87      100    48.70    48.70  msImageCopyMerge
 14.51      8.65     3.78      200    18.90    18.90  msImageInitGD
  2.99     19.79     0.78  3120400     0.00     0.00  msAddLine
  0.31     24.75     0.08   441600     0.00     0.00  msShapeObjIncBuffer
3. cvs version:
 time   seconds   seconds    calls   s/call   s/call  name
 86.61    163.87   163.87  3120400     0.00     0.00  msAddLine
  2.53    168.66     4.79      100     0.05     0.05  msImageCopyMerge
  1.99    172.42     3.76      200     0.02     0.02  msImageInitGD
Index: mapprimitive.c
RCS file: /data2/cvsroot/mapserver/mapprimitive.c,v
retrieving revision 1.53
diff -u -r1.53 mapprimitive.c
--- mapprimitive.c	14 Jun 2005 16:03:34 -0000	1.53
+++ mapprimitive.c	27 Jul 2005 14:01:26 -0000
@@ -1,4 +1,4 @@
  * Project:  MapServer
  * Purpose:  Implementations for rectObj, pointObj, lineObj, shapeObj, etc.
@@ -254,35 +254,27 @@
 int msAddLine(shapeObj *p, lineObj *new_line)
   int c;
-  lineObj *extended_line;
   /* Create an extended line array */
-  if((extended_line = (lineObj *)malloc((p->numlines + 1) * sizeof(lineObj))) == NULL) {
+  p->line = (lineObj *)realloc(p->line, (p->numlines + 1) * sizeof(lineObj));
+  if( p->line == NULL ) {
     msSetError(MS_MEMERR, NULL, "msAddLine()");
     return(MS_FAILURE);
-  /* Copy the old line into the extended line array */
-  for (c= 0; c < p->numlines; c++)
-    extended_line[c]= p->line[c];
   /* Copy the new line onto the end of the extended line array */
-  c= p->numlines;
-  extended_line[c].numpoints = new_line->numpoints;
-  if((extended_line[c].point = (pointObj *)malloc(new_line->numpoints * sizeof(pointObj))) == NULL) {
+  c = p->numlines;
+  p->line[c].numpoints = new_line->numpoints;
+  if((p->line[c].point = (pointObj *)malloc(new_line->numpoints * sizeof(pointObj))) == NULL) {
     return(MS_FAILURE);
-  memcpy( extended_line[c].point, new_line->point,
+  memcpy( p->line[c].point, new_line->point,
           sizeof(pointObj) * new_line->numpoints );
-  /* Dispose of the old line */
-  if(p->line) free(p->line);
   /* Update the polygon information */
   p->numlines++;
-  p->line = extended_line;
   return(MS_SUCCESS);
@@ -294,33 +286,25 @@
 int msAddLineDirectly(shapeObj *p, lineObj *new_line)
   int c;
     return(MS_FAILURE);
   c= p->numlines;
-  extended_line[c].point = new_line->point;
+  p->line[c].point = new_line->point;
   /* strip points reference off the passed in lineObj */
   new_line->point = NULL;
   new_line->numpoints = 0;
   p->numlines++;
   return(MS_SUCCESS);
