shapeObj buffer resize algorithm
Frank Warmerdam fwarmerdam at GMAIL.COM
Wed Jul 27 10:42:36 EDT 2005
On 7/27/05, Kovacs Baldvin <baldvin at cs.elte.hu> wrote:
> Well. The thing is, in my application there are lots of multilines.
Baldvin,
Ah, well this is (I think) uncommon.
> > I am somewhat concerned by your optimization because it now means
> > anywhere that creates a local lineObj needs to remember to
> > properly initialize the bufsize array.  You may have found and updated
> Hey, but I don't accept this. If one chooses not to use a correct
> object-oriented style, than one has to take the consequences.
Well, I would claim the consequence is a willingness to keep certain
core concepts unchanged rather than the consequence being that
messy things need to be put in many different places.
> I've attached a patch that makes the msAddLines variants to use
> relocate, but without introducing the manual heuristic. I think
> it is the reasonable solution...
I concur.  It seems to capture most of the benefit without the risk
of side effects.  I have submitted this as bug 1432, and will take
care of applying it this morning.  I think I will also remove the
duplication between msAddLine and msAddLineDirectly which is
my fault from previous efforts.
  http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1432
Thanks for the help performance tuning MapServer!
Best regards,
