Segmentation fault adding a new layer with php-mapscript
(4.6beta3)
Julien-Samuel Lacroix
jlacroix at DMSOLUTIONS.CA
Tue Jun 7 11:37:15 EDT 2005
I found the problem. Thanks for reporting it.
I opened bug 1375 to keep track of this issue.
The problem was that the USE_POINT_Z_M flag was not carried to mapscript
makefile. This caused mapscript and mapserver to have different mapObj
size.
Thanks
Julien
On 06/07/2005 02:42 AM, Nicol Hermann wrote:
> Hi Bill, Daniel, and all the others how replied
> i could isolate my problem to a single config option.
> When i remove the flag:
> '--enable-point-z-m'
> from the configure line (i need it for oracle spatial) everything works
> fine.
> When i enable it i get the described segfault.
> 0x4114ea30 in layerObj_new (map=0x41f88008) at mapscript_i.c:410
> 410 map->layerorder[map->numlayers] = map->numlayers;
> (gdb
> Could some comment on this or have the same problem?
> Many thank
> Nicol
Julien-Samuel Lacroix jlacroix at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
