Segmentation fault adding a new layer with php-mapscript (4.6beta3)
Steve Lime steve.lime at DNR.STATE.MN.US
Wed Jun 8 12:24:57 EDT 2005
This is PHP specific I take it, right?
Steve
>>> Bill Binko <bill at BINKO.NET> 06/07/05 10:45 AM >>>
Nicol, Julien
I found it as well... (bummer we overlapped efforts)
attached is a patch that you can apply Nicol (run patch < zm.patch from
the php3 directory) -- or you can grab CVS HEAD after Julien applies his
Bill
On Tue, 7 Jun 2005, Julien-Samuel Lacroix wrote:
> Hi,
> I found the problem. Thanks for reporting it.
> I opened bug 1375 to keep track of this issue.
> The problem was that the USE_POINT_Z_M flag was not carried to mapscript
> makefile.  This caused mapscript and mapserver to have different mapObj
> size.
> Thanks
> Julien
> On 06/07/2005 02:42 AM, Nicol Hermann wrote:
> > Hi Bill, Daniel, and all the others how replied
> > i could isolate my problem to a single config option.
> > When i remove the flag:
> > '--enable-point-z-m'
> > from the configure line (i need it for oracle spatial) everything works
> > fine.
> > When i enable it i get the described segfault.
> > 0x4114ea30 in layerObj_new (map=0x41f88008) at mapscript_i.c:410
> > 410         map->layerorder[map->numlayers] = map->numlayers;
> > (gdb
> > Could some comment on this or have the same problem?
> > Many thank
> > Nicol
