FLASH Output
Sture Dingsøyr candalt at ONLINE.NO
Mon Jun 13 15:00:56 EDT 2005
Have a FEDORA C3 box with Mapserver 4.4.2 installed. The installation works fine and it outputs images...no problem. We are using it in some applications.
But when i try to make Mapserver output Shockwave Flash movie nothing happens...
I run php 4.3.9 and php mapscript.
In the HTTPD log i get this message: [Fri Jun 10 08:59:12 2005] [error] [client xxx.xxx.xxx.xxx] Premature end of script headers: php
What could the problem be? Mapserver compiles fine with the ming parameter, and in php it outputs:
MapServer version 4.4.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
Mapserver is compiled with:
./configure --without-tiff --with-eppl --with-jpeg=/usr --with-threads --with-proj=/usr --with-gdal=/usr/local/bin/gdal-config --with-ogr=/usr/local/bin/gdal-config --with-ming --with-php=/usr/share/php439 --with-gd=/usr/local --with-freetype --with-wmsclient --with-wfs --with-wfsclient --with-postgis --with-curl-config=/usr/bin/curl-config --enable-debug --disable-ignore-missing-data --enable-runpath
and returns:
checking if MyGIS support requested... no
checking if OracleSpatial support requested... no
checking if MING/Flash support requested... yes
configure: checking whether we should include WMS Server support...
        OGC WMS compatibility enabled (-DUSE_WMS_SVR).
It says that MING/FLASH is supported...
We run ming-0.2a
Any good ideas?
Best regards sture
