4.6.0 final today
Paul Ramsey
pramsey at REFRACTIONS.NET
Tue Jun 14 13:52:31 EDT 2005
Fair enough, I can back down, I only really had the opportunity to
heavily test in the last two days, two months lead time notwithstanding.
Having run across some of the other quirks recently as a result of that
(Intersect vs Intersects) I am somewhat sensitive: broken standards
support is almost worse than none at all (as it raises expectations
before they are dashed).
<PAUSE>
So, I downloaded CadCorp MapBrowser, and it worked with mapserver 4.4
and 4.6. Only one problem, and that was when it was given a LineString
with only one coordinate (not legal GML). Which is a data or a server
problem, depending on where one wants to point fingers.
So I feel better that our 4.6 problem is very likely self-inflicted and
not something I should worry about in a larger context. Fire away, sorry
for the tempest.
Paul
FYI, fun with mapserver versions:
http://mapserver.refractions.net/cgi-bin/mapserv42?map=/home/www/mapserv/maps/victoria-wms.map
http://mapserver.refractions.net/cgi-bin/mapserv44?map=/home/www/mapserv/maps/victoria-wms.map
http://mapserver.refractions.net/cgi-bin/mapserv46?map=/home/www/mapserv/maps/victoria-wms.map
http://mapserver.refractions.net/cgi-bin/mapserv42?map=/home/www/mapserv/maps/elections-wms.map
http://mapserver.refractions.net/cgi-bin/mapserv44?map=/home/www/mapserv/maps/elections-wms.map
http://mapserver.refractions.net/cgi-bin/mapserv46?map=/home/www/mapserv/maps/elections-wms.map
Both are dual-mode WFS/WMS files, it was fun to see how things changed
(or not) across versions.
Daniel Morissette wrote:
> Paul Ramsey wrote:
>> Gah. :) When it comes to standards, releasing broken things is really
>> catastrophic to the ecology of technology. (Speaking as someone who
>> has a client.) It makes things look randomly broken, even when the
>> client software is good. I am in a huge MUM rush, it is going to be
>> hard to make time to DL mapbrowser and try this out, but will try.
> We've been walking towards this release for almost two months now, it's
> a bit late to bring this up now at a few hours from the final release.
> Are there bugs documenting those issues?
>> If there *is* a problem, I would suggest that delay is better than
>> broken standards support.
> I guess I'd submit this to a vote of the other developers (I have CC'd
> mapserver-dev to get other developer's opinions). My personal vote goes
> to NOT delaying the release and including the fix in 4.6.1 (assuming
> there is an issue).
> Daniel
>>> Paul Ramsey wrote:
>>>> Daniel,
>>>> Has the 4.6 WFS support been tested with a WFS client like Cadcorp
>>>> SIS or something else with reasonable GML support? We have thus far
>>>> failed to be able to consume Mapserver 4.6. While we have no reason
>>>> to blame mapserver (it could easily be our fault) in general
>>>> mapserver WFS does not get tested as heavily as the WMS, so it would
>>>> be nice to have another data point that indicates that our problem
>>>> is in fact our fault, and not Mapservers.
>>> You're right that MapServer's WFS doesn't get tested as much as the
>>> WMS with 3rd-party clients, simply because WFS is not as widely used
>>> as WMS. We know that Tom and Bart (CC'd on this reply) use it a lot,
>>> so they may be able to comment on the testing they've done.
>>> Unfortunately I don't think there is much we'll be able to do on WFS
>>> before the 4.6 release if we want it out today, so if any fixes are
>>> required they would have to wait for 4.6.1 (and after MUM3).
>>> BTW, have you tried testing it with Cadcorp Mapbrowser? How did it
>>> go? I think we've used MapServer with it succesfully in the past, but
>>> maybe some recent changes broke something?
>>> Daniel
