WMS GetFeatureInfo output formats
Paul Ramsey
pramsey at REFRACTIONS.NET
Mon Jun 20 12:55:03 EDT 2005
Hmmm, this is going to be less useful than I thought. The old ArcIMS WMS
extended actually advertised "ARCXML" as a return type, which would have
been very handy. The new one advertises "text/xml", which is less useful
as a MIME type.
http://gisdata.usgs.net/servlet19/com.esri.wms.Esrimap/USGS_EDC_National_Atlas?Request=GetFeatureInfo&QUERY_LAYERS=ATLAS_STATES&VERSION=1.1.1&WIDTH=100&HEIGHT=100&BBOX=-149.133392830226,35.6746917523835,-45.788208504046,49.3980488024172&SRS=EPSG:4326&INFO_FORMAT=text/xml&X=50&Y=50
Paul
Kralidis,Tom [Burlington] wrote:
> Would you have some comparison of ArcXML vs. current WMS GetFeatureInfo
> XML response? I'd be interested to see what can be gained here, as
> opposed to adding another format.
> ..Tom
>>-----Original Message-----
>>From: Paul Ramsey [mailto:pramsey at refractions.net]
>>Sent: Monday, 20 June, 2005 12:14
>>To: Kralidis,Tom [Burlington]
>>Cc: MAPSERVER-DEV at LISTS.UMN.EDU; Mark Leslie
>>Subject: Re: [UMN_MAPSERVER-DEV] WMS GetFeatureInfo output formats
>>Using GML 2.1 would allow uDig to consume the results a
>>little easier...
>>so I would like that :)
>>On an unrelated note, would anyone object to our adding ArcXML as an
>>output format for GetFeatureInfo? It is actually the best fit for
>>Mapservers internal data structures, and is already advertised by a
>>large number of "WMS" servers :)
>>Paul
>>>Now that WFS GetFeature responses are valid XML for both GML2 and
>>>GML3L0 (good work Steve!), and given bug
>>>http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=801, this
>>might be a
>>>good time to clean up WMS GetFeatureInfo to produce valid
>>XML. Having
>>>said this, should we also provide finer grained MIME types for
>>>supported GetFeatureInfo, i.e.:
>>>application/vnd.ogc.gml
>>>application/vnd.ogc.gml3l0
>>>...or should we just cite application/vnd.ogc.gml and use GML3 from
>>>here on in. Interested in people's comments on this one.
>>>..Tom
