MapServer Development Process?
Steve Lime
steve.lime at DNR.STATE.MN.US
Thu Jun 23 18:35:43 EDT 2005
>>> Sean Gillies <sgillies at FRII.COM> 06/23/05 11:14 AM >>>
> Hi all,
> After listening to van Gulik's presentation, does anybody feel that the
> MapServer project might benefit from a harder look at its development
> process?
Yes, but that feeling will wear off I hope. ;-)
> I like the voting idea, and I think we should adopt it. I also think
> that votes should be weighted by the number of tests that you have
> written and committed to CVS ;) That was a joke. A voting system will
> require better communication. The Apache projects demand that all code
> decisions take place in the open, and we should adopt this as well.
> This means that decisions will not be made between Howard and I on IRC,
> or behind closed doors at DM Solutions. In the open means on the
> mapserver-dev list. We do a fair job of this, but it could be better.
> Writing this in stone and holding each other to it could help to head
> off future problems.
Frank has done a nice job on more than one occation of submitting proposals
for largish modifications (e.g. rotated maps) to this group. I would like to
see more of that personally. Perhaps Frank could post that example for folks
to take a look at. If I recall correctly with the groups help there were siginificant
changes made to the implementation that resulted in an easier to use feature.
> It's also long past time to have some tests for MapServer. I propose
> that we start with the new input plugins: no plugins committed without
> tests. These should be tests that can be run under valgrind, and should
> also be automate-able.
I have no problems with this. The process for writing tests, submitting them and
so on needs to be well documented and understood by those doing development.
> My last point is not so much about process as about direction and
> design. I cracked Frank up after the conference by asking what he
> thought about how successful Apache became following a complete
> re-write. I was only half joking. MapServer, as a prominent user said
> to me, has no architecture. Do we put off creating an architecture
> until it becomes practically impossible to add new useful features? It
> seems to me that GRASS got in trouble this way. Do we really want to
> wait until MapServer is widely perceived as clunky and fragile before
> making a change?
I don't know that I agree with no architecture. It's not perfect but then what is. The
map->layer->class/shape architecture works pretty well for what it was intended. I'm
not at all for re-writes for the sake of re-writing. If you see opportunities then by
all means speak up and make some proposals. I'm not afraid of major change if
there are good reasons to do so.
Steve
> cheers,
> Sean
