MapServer Technical Steering Committee Proposal
Frank Warmerdam
fwarmerdam at GMAIL.COM
Fri Jun 24 17:16:56 EDT 2005
Folks,
We have had lots of talk over the last year or more about "process"
but without a process to make a decision we haven't really done anything.
I have prepared a proposal for a mechanism, which is attached and
also available in CVS under rfc/ms-rfc-1.txt.
I am first putting this up for discussion but assuming relatively positive
feedback I will seek unanimous approval by the proposed voting members:
Steve Lime, Daniel Morissette, Frank Warmerdam, Sean Gilles, Assefa
Yewondwossen, Howard Butler and Perry Nacionales.
This isn't meant to be the be-all and end-all of committee constitutions.
Just enough process to get us going so we could decide a few other
things and know we have reached some sort of closure.
MS RFC 1: Technical Steering Committee Guidelines
Author: Frank Warmerdam, Independent, warmerdam at pobox.com
Proposed: 2005/06/24
Status: Proposed
Summary
This document describes how the MapServer Technical Steering Committee
determines membership, and makes decisions on MapServer technical issues.
In brief the technical team (primarily developers with commit priviledges)
votes on proposals on mapserver-dev. Proposals are available for review
for at least two days, and a single veto is sufficient delay progress though
ultimately a majority of members can pass a proposal.
Detailed Process
1) Proposals are written up and submitted on the mapserver-dev mailing
list for discussion and voting.
2) Proposals need to be available for review for at least two business
days before a final decision can be made.
3) Detailed proposals, especially those that are likely to live
for a long time, should be written up in flat text, and submitted in
mapserver/rfc (in CVS).
4) Respondents may vote "+1" to indicate support for the proposal and a
willingness to support implementation.
5) Respondents may vote "-1" to veto a proposal, but must provide clear
reasoning and alternate approaches to resolving the problem within the two
days.
6) Anyone may comment on proposals on the list, but only members of the
Technical Steering Committee's votes will be counted.
7) A proposal will be accepted if it receives +2 (including the proposer)
and no vetos (-1).
8) If a proposal is vetoed, but an absolute majority of committee members
support the proposal (with +1's) then it passes.
9) Upon completion of discussion and voting the proposer should announce
whether they are proceeding (proposal accepted) or are withdrawing their
proposal (vetod).
10) The Chair gets a vote.
11) The Chair is responsible for keeping track of who is a member of
the Technical Steering Committee (perhaps as part of a TSC file in CVS).
12) Addition and removal of members from the committee, as well as selection
of a Chair should be handled as a proposal to the committee.
13) The Chair adjudicates in cases of disputes about voting.
When is Vote Required?
o Anything that could cause backward compatability issues.
o Adding substantial amounts of new code.
o Changing inter-subssytem APIs, or objects.
o Issues of procedure.
o When releases should take place.
o Anything that might be controversial.
Boundaries of "Technical"
o If it relates to changes in the code, it is technical.
o If it relates to how the developers cooperate, it is technical.
o If it relates to documentation, or web site it is arguable whether
it should be decided by the technical steering committee.
o If it relates to events such as conferences, it is not technical.
Observations
o The Chair is the ultimate adjudicator if things break down.
o The absolute majority rule can be used to override an obstructionist
veto, but it is intended that in normal circumstances vetoers need to be
convinced to withdraw their veto. We are trying to reach consensus.
o It is anticipated that seperate "committees" will exist to manage
conferences, and possible documentation and web sites.
Bootstrapping
Steve Lime is declared initial Chair of the Technical Steering Committee.
Yewondwossen, Howard Butler and Perry Nacionales are declared to be the
founding Technical Steering Committee.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
