Odd issue with drawing a shape multiple times
Sean Gillies
sgillies at FRII.COM
Tue Mar 1 11:29:30 EST 2005
Can anyone share their insight into shape rendering with me? I'm
finding it impossible to redraw a single shape using the same map and
layer objects using shapeObj.draw (and msDrawShape). Is there some
caching or other magic at work here that's tripping me up?
The script is run from mapserver/tests:
import mapscript
mo = mapscript.mapObj('test.map')
# Use the POLYGON layer to render feature
lo = mo.getLayerByName('POLYGON')
# Get one polygon shape
lo.open()
so = lo.getFeature(0)
lo.close()
so.classindex = 0
def inspect_shape(so):
for item in dir(so):
print item, getattr(so, item)
# render the shape
im = mo.prepareImage()
print "p1a\n---\n"
inspect_shape(so)
so.draw(mo, lo, im)
im.save('p1a.png')
# render the shape in a new image
print "p1b\n---\n"
inspect_shape(so)
so.draw(mo, lo, im)
im.save('p1b.png')
Produces the images
p1a (is correct):
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20050301/1e781f2f/p1a.png
p1b (is blank):
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20050301/1e781f2f/p1b.png
I'm stepping through the code with gdb but am finding it to be slow
going. Any clues from the mapdraw.c and mapgd.c programmers (Steve?)
would be greatly appreciated!
thanks,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
