Wrong query results on SDE layer
Pirmin Kalberer
sp_ml at SOURCEPOLE.COM
Fri Mar 4 04:47:55 EST 2005
Howard,
Am Donnerstag, 3. März 2005 18.12 schrieb Howard Butler:
> First, there is a define at the top. #define MS_SDE_ROW_ID_COLUMN
> "SE_ROW_ID"
> Whenever something like InitItemInfo (get the layer information, find the
> column names, etc) is done, msSDELayerGetRowIDColumn is called. It is in
> this function where all the business of finding the unique row id column is
> done.
> If the table is not registered as versioned, then msSDELayerGetRowIDColumn
> will only return the MS_SDE_ROW_ID_COLUMN value.
> Try setting MS_SDE_ROW_ID_COLUMN to "OBJECTID" and recompiling or
This was the first thing I tried. But after that I didn't get any query
results :-(
As far as I remember, even the SDE raster layers were broken.
> registering the table as versioned so msSDELayerGetRowIDColumn can
> calculate it. If you have *multiple* SDE layers in a mapfile and they have
> different unique columns (ie, one table uses OBJECTID and the other uses
> SE_ROW_ID), you are in a bit of a bind unless the tables are registered.
We have many SDE layers (raster & vectors), but I think that they all use the
same unique column. Registrating one layer as versioned didn't change the
behaviour.
Pirmin
> At 03:31 AM 3/3/2005, Pirmin Kalberer wrote:
> >We have a problem with queries on SDE layers.
> >After updating Mapserver from 4.2 to 4.4.1 we get "random" results using
> > the Identify function of Chameleon. The returned result sets let me
> > suspect that SE_ROW_ID and OBJECTID are confused somehow. But I couldn't
> > find OBJECTID anywhere in the source code. We tested with SDE 9 and 8.3
> > (but client lib 9). For me it looks like a mapserver bug (what I almost
> > can't believe). Or are there any other ideas?
> >Regards,
> >Pirmin
> >Pirmin Kalberer
> >Sourcepole - Linux & Open Source Solutions
> >http://www.sourcepole.com
Pirmin Kalberer
