gfs output in Maserver 4.5 using gdal1.2.5
Frank Warmerdam
fwarmerdam at GMAIL.COM
Tue Mar 8 16:18:55 EST 2005
On Tue, 8 Mar 2005 15:47:48 -0500, Yewondwossen Assefa
<assefa at dmsolutions.ca> wrote:
> Hi There,
> I was just testing the wfs output and came accross an issue that I do
> not really understand. The wfs get feature request produces a gml and a
> gfs file. In Mapserver 4.4.X (using gdal1-2.5), the gfs contains
> attribute informations (<PropertyDefn>) . In Mapserver 4.5 (gdal1.2.5),
> the attributes informations are not included in the file.
> Does anyone has a quick explanation on this ? I am using the same test
> map file in both cases.
Assefa,
This is using MapServer as a WFS server (not a client), right?
I didn't think that MapServer itself would write out a .gfs file to
go with a .gml result. My understanding was that .gfs files
are only created by OGR when opening a previously unopened
gml file.
I have done quite a bit of work in GDAL post-1.2.5 to support
GML 3 Level 0 schemas, and in this case OGR is not supposed
to create a .gfs file. But you mention you are using GDAL 1.2.5
in both cases, right?
Are the GML files similar?
I'm pretty confused too!
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
