debug and Mapserver crash
Bart van den Eijnden
bartvde at XS4ALL.NL
Mon Mar 14 08:53:34 EST 2005
Hi Steve,
my experience is that nothing is debugged to stderr on a crash (except
premature end of script headers, mapserv.exe), but I was wondering if this
would be logical and if others have experienced this behaviour. My
experience is only on the Win32 platform though.
I do agree with you that levels would be a very welcome enhancement.
Best regards,
Bart
On Mon, 14 Mar 2005 08:53:28 -0500, Stephen Woodbridge
<woodbri at SWOODBRIDGE.COM> wrote:
> Bart,
> I'm not sure what happens on a crash, but my experience with the DEBUG
> and LOG are as follows.
> 1) If LOG is turned on it only writes one line to the logfile that I did
> not find to be very useful for anything.
> 2) DEBUG output does NOT go to the LOG file it goes to STDERR which
> should put it into the apache/error_log. I opened a separate window and
> did a "tail -f /var/log/apache/error_log". FWIW, the only information
> written during DEBUG is layer timing stats. so if the files are flushed
> on a crash, you might get a clue about what layer it crashed on.
> While this is better than nothing, I would be nice if the DEBUG took a
> LEVEL which controlled the level of verbosity of the output as a bit
> mask or level like:
> DEBUG 1 - timing stats
> DEBUG 2 - subroutine
> DEBUG 4 - file/connection OPEN/CLOSE
> DEBUG 8 - SQL statements
> DEBUG 16 - etc
> But alas, it doesn't work that way.
> HTH,
> -Steve W.
> Bart van den Eijnden wrote:
>> Hi list,
>> does Mapserver write debug info for the functions that are successfully
>> called before a crash (Internal Server Error) occurs?
>> Or when it crashes it won't write anything at all?
>> Best regards,
>> Bart
>> Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
