WFS client problem on Windows 2003
Bart van den Eijnden
bartvde at XS4ALL.NL
Mon Mar 14 10:32:19 EST 2005
Hi Daniel,
yes we tried increasing the timeout to 2 minutes, which resulted in the
same behaviour of the CGI. The crash occurs before the timeout.
When we put a really low timeout value of 5 seconds, we got a nice
Mapserver exception that the timeout was exceeded.
Best regards,
Bart
On Mon, 14 Mar 2005 10:31:29 -0500, Daniel Morissette
<dmorissette at dmsolutions.ca> wrote:
> Bart van den Eijnden wrote:
>> 1. using the curl utility always the full document is retrieved,
>> although
>> times differ a lot between 10 and 65 seconds
>> 2. Mapserver does not download the full file, it downloads a part of
>> it,
>> and the part that it downloads differs all the time.
> Did you try increating the wfs_connectiontimeout metadata value? The
> default is 30 seconds. If the response from your WFS takes more than 30
> seconds to arrive then the transfer could be aborted and that could
> explain the behavior that you've seen.
> Daniel
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
